Flight Plan Transfer FF to iFly
F1Rocket
I see that it is now possible to transfer from iFly to Foreflight. Is it possible to import a Foreflight plan into iFly easily?
Yes I fly with friends that use FF and I use iFly. I have also used FF because I had previously only been able to import our flight plan manually. That leaves an opening to errors, not a good thing.
Yes. If the FF user exports their flight plan to an .fpl file and you can get it onto the device where you run iFly, you can go to Flight Plan > Load Plan > <IMPORT...> (if you have a lot of saved flight plans you'll need to scroll to the bottom to see this option), then navigate to the .fpl file you want to import.
one caveat, in the current iOS version there is a bug that is preventing it from working. @Brian is aware and it is on the list for post Airventure.
