Accessory Power
Aviator
I am considering purchasing the iFly EFB tablet, to replace my 720.
If is not clear to me that the tablet has a port which can be connected to the aircraft power (not via USB). I do not see any mention of a cable for this purpose either included, or available as an accessory.
I see that the docking station can be connected to aircraft power, but I do not think the docking station would be my preferred solution.
Can the tablet be powered by a readily available stand alone battery, similar to how I powered the 720 and 740? (I'd prefer NOT to power it off ships' power.)
It's just an Android tablet, so "yes".
But what is your rationale for avoiding ship's power? If because your plane has a very marginal power supply and you need every electron for other critical usage, that makes a lot of sense.
But if your rationale is that you're trying to maintain true independence / redundancy and are separating your tablet power from ship's power for that reason...well, again recall that it's just an Android tablet and is designed for portable usage. Unlike the 7xx devices that did not have their own internal batteries, a fully-charged iFly Aviation Tablet will run for hours on its own battery.
So, charge it before you leave home, then plug it into ship's power during flight so that it remains fully charged, and then if you lose ship's power, the tablet running on its own battery will almost certainly outlast your aircraft's fuel endurance. It will also probably run a lot longer than you'll want to remain aloft without power to your plane's other electrical equipment.
FWIW, I started with a 700 and upgraded to a 720. I had a complete loss of electrical with the 720 when I was only using ship's power, and quickly bought a battery to avoid that situation in the future. But when iFly became available on tablets, I started using it there as my primary source. I long ago retired the 720, and now have a tablet on each yoke, both kept fully charged by ship's power as described above.
My main reason to power the tablet w a battery (back up) is I don't have ez access to an avionics shop to do the hard wiring installation, nor do I want to take on that additional expense since I have many portable batteries and I am used to connecting a cord to power the 740 device. I also want to avoid that (cumbersome) docking station and RAM mount ($179+) If I go with the tablet, I'll modify the 740 yoke mount to accept the tablet.
I do agree that utilizing ships' power is the simpler solution, but that doesn't work for me.
Ah, okay. My plane has a cigarette lighter, and I just use an adapter (like the one below) to supply a USB-C cable that I plug into the tablet. Easy peasy for me, but maybe not everyone has such an option. (I use a RAM mount to hold my Samsung Tab S6 on the yoke; the iFly Aviation Tablet is a similar size and I would use it the same way if I bought one.)
