- Nov 10, 2025
Foreflight has a feature where you can view Air Traffic via the internet when not connected to ADSB. While connected to ADSB, the real-time ADSB supercedes for local traffic.
From FF website: Stream live global aircraft traffic directly in ForeFlight with the Internet Traffic feature. In partnership with FlightAware, ForeFlight allows you to view airborne traffic around the globe, and ground traffic at thousands of airports worldwide, to help you gauge airport activity like active arrivals and runways, see how ATC vectors traffic around weather, or assist with plane spotting on the ground.
Turn on the Traffic layer by tapping Map layer selector (button in the top left corner) > Traffic. Internet Traffic is associated with the same map layer as ADS-B traffic and is selectable when connected to the internet on the ground or via inflight Wi-Fi like Gogo and Satcom Direct. When you connect to an ADS-B receiver, the Traffic layer will automatically switch to displaying only ADS-B traffic received from the device and stop showing Internet Traffic unless you’re connected to inflight Wi-Fi. The timestamp in the top-left of the map displays the source of traffic any time the Traffic layer is enabled.
Like ADS-B traffic, Internet Traffic displays both airborne and ground targets with at-a-glance altitude and tail number or callsign, if available. Unlike ADS-B traffic, which shows each target’s altitude relative to your own, Internet Traffic shows each target’s pressure altitude directly. Tap on any traffic target to view more information about it, including its distance and bearing from your position, its heading, speed, aircraft type, the source of the aircraft’s position report, and a timer indicating the age of the last report.
Position reports for Internet Traffic are less frequent compared to ADS-B traffic, so ForeFlight uses the last-reported position, heading, and speed of airborne traffic to interpolate its movement and smoothly animate it on the map. Aircraft that are turning or changing speed causes the icons to race to catch up to the actual position from the expected position. For this reason, Internet Traffic should not be used for inflight traffic avoidance or tactical decision making.
ForeFlight filters out what traffic it displays to minimize clutter and excessive data usage. Zoom far out to only show the highest-altitude traffic, and zoom in to view progressively lower altitude traffic. Ground traffic fades into view withForeFlight’s embedded airport diagrams, while high-altitude traffic is hidden at this level. Position reports for ground traffic are delivered more frequently than for airborne traffic, so ForeFlight doesn’t animate movement on the ground.
