Android 14 Task Bar
Agilestick
I just updated my Thork Racing tablet to Android 14. There is now a taskbar that appears while using the iFlyEFB app that takes up a portion of the screen. It wasn't there in ver. 13. I cannot find any way to remove it - but I'm not that familiar with Android tablets. The task bar has the iFlyEFB app icon, and the triangle, circle, square Android icons.
Here's a suggestion to try - most Android tabs have a setting that toggles between using the 3 button navigation icons (as you described) and gestures (swiping up/down/side to side to navigate through the apps and screens). I'm running Android 14 as well and found the setting by opening up the settings menu and searching for Navigation. Hope this helps and welcome to the Forum.
If you have changed the system font size or display magnification to something higher than the original/default settings, I have seen that have the effect of causing some apps to "extend underneath" the navigation buttons at the bottom of the screen. Could that be contributing to the behavior you're obseerving?
