Are the takeoff minimums in IflyEFB somewhere?
Hi Mike!
Yes! Takeoff minimums are available in iFly EFB.
When you are hovering over an airport on the map, tap on the Plates button on the right hand side of the screen (right above the + / -) and then tap on Takeoff Minimums. Note this pulls up the whole Takeoff Minimum document for the state, so you will have to scroll to the Airport you are looking for. Alternatively, you can tap on an airport and then tap on View Plates in the QuickView pop up.
