- Apr 13, 2023
This is not a feature addition request, but rather a request to change behavior of an existing feature.
iFly allows users to share data and configurations across devices via "syncing" (Menu > Setup > Sync devices...), which uploads the data from a source device to the Adventure Pilot cloud, so that other devices can subsequently pull the data back down from the cloud.
This works well, but can have unintended consequences that can cause loss of data. For instance, if a user creates two different flight plans on two different devices but each has the same name, then the user syncs flight plans from one device to the other, the flight plan with the same name on the 2nd device will be overwritten by the downloaded plan from the 1st device and the user will not be warned.
So I request that iFly warn the user of the potential to overwrite data. At a minimum, iFly should pop a warning that advises of the possibility in general, to prompt the user to think, "Am I syncing data that might get overwritten?"
However, it would be better if iFly were "smarter" about warning the user: iFly should be able to recognize if any of the about-to-be-downloaded files have the same name as existing files on the destination device, and explicitly warn the user, "The following files will be overwritten. Do you want to proceed?" Even better would be to present that list of files with a checkbox by each file, so the user can pick and choose which files are okay to overwrite, and which ones should not be.
And even better still, this proposed "overwrite protection" improvement could also be implemented in the "upload" phase (from a source device to the AP cloud), as well.
Thoughts?
Thoughts?
