I recently noted that when the ifd100 app is connected to the ifd and you start IflyEFB then I go back to the ifd100 app it no longer has a connection to the ifd. Both Ifly and the miniipad have the lastest versions as of 12/29/24. If you start ifly first and then start the ifd100 app it will not connect and see the ifd. Per avidyne both the ipad and the ifd have to be connected to the wireless adsB source (for me its stratus). Has anyone else experienced this and have you found a solution. I thought it was working in the past but maybe I was wrong. Being able to use both programs is a plus as they give different info and it makes a great backup.
