V14 problems on mini ipad
khafner
Just downloaded V14. I love the graphics. When in map mode instruments the instruments overlap and obstruct each other. The other problem is that while I can be in full screen mode in protrait position it will only go to about 45% of screen in landscape mode (it believes it is in full screen mode). Has anyone else seen this and have you found a fix? I use mine exclusively in landscape mode.
An update. I use my ipad in window'd mode to be able to use multiple apps while flying. When I turned this off things worked. The previous version worked well in window'd mode. So I turned it back on and now I can see ifly in full screen mode in the orientation that it is started in. It will not fix in that mode and if the ipad is rotated it rotates to half screen mode and goes back to full mode when rotated again. If you shrink the screen part of it goes off the edge but is usable. The instruments are no longer overlapping (they did need to be reset).
