Ability to set a minimum altitude with voice announcement
n9732j
I would like to be able to set a "minimum" altitude and have voice announcements at 500 feet above that altitude and every 50 or 100 feet as I get closer to the minimum.
Not sure how you would use that. The "500" (AGL) is standard; what I'd like to see is callouts from there to ground: "250...100...50...25...10"
Now THAT would be really helpful!
You’d need to enter the altimeter setting and have a device that provides pressure altitude, or your actual altitude may not match the callouts to the precision you’d like. Even worse if based solely on GPS
