If you really want to get rid of WACs, you certainly can: Menu > Check for Updates > Advanced Options, uncheck WAC, and click the "Delete Unselected Data" button.
But before you do, here's an explanation of why they're still there:
The WAC charts are definitely a compromise and they have pros/cons. The benefit of the WAC charts is that for a one-time download (since they're no longer supported / updated), iFly can populate a basic map of the entire US. Users will never pan to a part of the country that's "blank" because they don't have any data at all for it. The drawback is that...well, they're WAC charts, and as you say, they're no longer supported and thus becoming more obsolete as time passes.
iFly tries to mitigate the downside of WAC charts when it can: When on the ground and connected to a good Internet source (or, if you're lucky and happen to have a data connection in the cockpit), if you pan outside the area where you have downloaded data, then iFly will download more Sectional data on-the-fly.
But iFly relies on the WAC charts when there is no other option: In the cockpit when you don't have a good data connection, you may be stuck with only the data you previously downloaded. Without the WAC charts, that means you might pan into an area with no data and so it would just be blank.
Thus, in other words, even though WACs are no longer updated, Adventure Pilot currently believes providing users with the WAC charts is still better than nothing.
If you want to maintain full US map data but hate WACs, then you absolutely can uncheck WACs but select all the states in the US to ensure you have Sectional maps offline. However, that's a lot more data than using WACs plus only data from the areas you're really likely to fly, especially since Sectionals update every 56 days.
Or you can go old-school like pilots flying with paper charts before the ubiquity of tablets and moving maps in the cockpit: Uncheck WACs, select the states you plan to fly in, and just accept that if you're in the air and don't have an Internet connection, there will be parts of the country for which you simply don't have any map data.
