Find Nearby Airport
DickF
Please add “Search by code/name” selection to the Find Nearby Airport screen. As it is now if the airport you are looking for is not listed you need to select “close” and effectively start over.
Until they do, you might try this. I just did with the Win10 version of EFB and it seemed to work.
1 Click the "Flight Plan" button.
2 Click "Enter Flight Plan" button. If you're on or over an airport, the search box should already be populated with the airport id.
3 Click "Done"
4 Click "Add Waypoint" You can now use the Search box to find the path to the airport you want.
5 Click "Close" to adopt the path to that airport.
If you're NOT near enough to an existing airport replace #2 above with #2 below.
2 Click "Lat/Lng..." A dialog box will come up with your current position.
It takes a few more clicks, but should work for you until your feature is adopted.
