Per Brian's request, I am posting this as an official feature request. This has been requested by me and others many, many times, for a few years now. But he'd like to get a measure of the demand. So if you would like to see an option available that turns on some kind of airborne indicator of how far you could glide if your engine quit then please "upvote" it (use the up-arrow to the right of this post). Feel free to post a supportive reply also, but what's going to count is the count to the right.
What I think we're all envisioning is some kind of indicator around the aircraft icon while in flight. A (sort-of-circular) line, or translucent "blob". But post any other ideas you have for what would be a good indicator.
In a good model of glide distance, that ring/blob would not be perfectly circular. Besides using the glide ratio you entered in your aircraft profile, it would take into account that you will lose altitude (and therefore glide distance) if you turned left or right or 180 degrees, and also use the forecasted (or computed?) winds aloft to figure how far you could go in various directions. It could even take into account terrain. Personally, a rough first cut would be satisfactory to me just for the sake of getting this off the drawing board. Even as simple as a perfect circle around the plane based on just the glide ratio. Improvements can be made over time. If you agree with that sentiment you might also want to mention that in a post.
Brian: besides making this a optional always-on indicator, I'd also like to see it as an option for when you hit the emergency icon (red triangle) in the NRST (nearest) popup window. That is, I would like an option that says "Turn on glide ring in emergency". That way, if I happen to not be flying with it on at this moment, it will come up when I most want it.
