Keyboard/Tablet Click on Ipad Mini?
Steve
Has anyone noticed the absence of "click sounds" when using an iPad-Mini?
I have both an Ipad and Ipad Mini, both running IFLYEFB version 13.3.53. The Ipad Mini is running iOS 15.8.4 and the Ipad is running iOS 16.7.11. Keyboard Clicks are enabled on both tablets. Volume controls are set at Max.
Thanks,
Steve
I am running a beta version of iFly that is more recent than your production version, but on my iPad Mini 5 I hear the button clicks as expected.
Just to be clear, there are two volume settings at play here: One on the iPad itself, and one within iFly. Make sure your iPad volume is set appropriately using the side buttons, but also make sure the iFly volume is set to an audible level:
Menu > Setup > Screen/Audio Settings > Sound Volume
Note that the iFly volume setting applies to all iFly audio (key clicks, traffic alerts, etc.).
Cobra,
I had previously verified every item that you mentioned. Thanks for your reminder.
Steve
Hm. Do you get any of the other iFly audio? For instance, when you change the "Sound Volume" selection within iFly, do you hear the <dong> sound? (It seems to have a "cooldown timer", so if you make selections too fast it doesn't chime each time--more like every 2nd or 3rd time. But if you wait a couple of beats between selections, it'll play every time.)
Yes, I can hear the "dong" but it is really muted, barely audible. Guessing that maybe there is something else in the iPad Mini that is attenuating the sound.
Steve
Steve
Yes, it seems like this is a problem unique to your individual Mini device.
I have iFly EFB V14.0.2 running on an iPad Mini4. Edited a flight plan name, and using the keyboard I can hear the clicks.
