Details, indeed.
You've got something going on with your situation--it's not a problem with the version build. I just downloaded the .msi and installed it over my current beta version, and this is what I see with the "About > Version" and "What's New?":
View attachment 260 View attachment 261
I think you probably have both 11.1.25 and 12.1.6 installed, and you're mistakenly launching the wrong one.
Try this:
- In the Windows search box, type "add remove" (no quotes) and then click on the "Add or remove programs" search result
- In the "Installed Apps" window that appears, type "ifly" (no quotes) into the search field
- See how many different versions of iFly are installed. There are probably two or more (including "iFly GPS" for the v11 instances), and the version numbers should be listed.
- You could try uninstalling the versions other than 12.1.6 and see if iFly works fine after that. If you run into any trouble, uninstall all versions, then reinstall the one you want (i.e., 12.1.6 as of today)
Please report back on how that goes for you.
