There is no purchase required for the app, only for the data. However, if you already have a data subscription for your 740, then you can also use a phone or tablet with it for no additional cost (actually two phone and/or tablet devices, if they are both on the same OS).How do I get it for free since I own your portable?
Thanks Cobra, got it to work and was able to register my iPhone. I had forgotten my password. Wish there was a way to highlight it when resetting. It took several tries till I got it right.There is no purchase required for the app, only for the data. However, if you already have a data subscription for your 740, then you can also use a phone or tablet with it for no additional cost (actually two phone and/or tablet devices, if they are both on the same OS).
I think if you launch the app, it might prompt you at startup to buy a subscription or log into an existing account, so you can either follow that path to log in, or else once the app has started you can tap the Menu button, and I think the option at the top of the list is to buy a subscription or log in. (Sorry for being vague...the login option only appears if you're not currently logged in, and I don't want to log out just to see what it says because I have a very convoluted password and don't want to retype it!)
The user credentials are the same ones you would use to log into the iflyefb.com website, not these forums.
There's a user interface overhaul coming "soon-ish". I expect that's one of the areas that will see improvement when that happens. (And now you know why I didn't want to log out and back in again!Thanks Cobra, got it to work and was able to register my iPhone. I had forgotten my password. Wish there was a way to highlight it when resetting. It took several tries till I got it right.
