John,When I look to select my departure time in the flight plan it indicates “(utc -3)” which is incorrect. How do I fix that?
Thanks,
John
What time zone are you in? I'm in Eastern, and on my iPad Mini 6 iFly shows "utc -4"--which is correct for Daylight Time--and the correct local time. But on my iPhone 14 Pro Max iFly shows the correct local time, but no hint of the utc offset.When I look to select my departure time in the flight plan it indicates “(utc -3)” which is incorrect. How do I fix that?
Thanks,
John
I just asked about this. Don't hit the "Get Brief" button. Go into "File a new plan" and make sure the time is ok. Then get the brief from that menu.Hmm, I am trying out the demo. The first time I obtained a briefing, that departure date/time "stuck" and I get the "more than 2 hours old" complaint. This happened only for that particular flight plan, even after clearing and reloading the saved plan. But, I do see that problem go away, so maybe exiting Ifly EFB(ipad) or something else has fixed the error. Editing the departure time does not help.
Ipad mini 2, IOS 12.5.7, Ifly 12.2.34
Regards
That's a great tip! If I can remember it, it ought to help me many many times over. (But it should be made obvious in iFly!)I just asked about this. Don't hit the "Get Brief" button. Go into "File a new plan" and make sure the time is ok. Then get the brief from that menu.
