- Apr 13, 2023
Adventure Pilot released version 12.2.19 (12.2.20 for Windows) of iFly EFB for Android (via the Google Play store), iOS (via the Apple App Store), and Windows (via the iFlyEFB.com website) today. Two new features were added: Glide Range, and Avidyne IFD integration.
Here are the release notes for this version:
Version: 12.2.19 (7/17/2023)
- Added Glide Range Layer
To enable, select bottom button Map Mode, then scroll down to 'Glide Range' and enable it. This will show a throbbing green ring around your aircraft during normal flight, showing you where iFly believes you can safely glide to a landing. Tap bottom button "NRST" then the "!" red emergency button at top right to enable Emergency mode.
In Emergency mode, iFly EFB shows you 2 Glide Rings in bold:- Green ring marks the safest glide areas, while
- Red ring marks the range that you should be able to glide to landing but is more of a risk
- Full Integration with Avidyne IFD
To connect, select Menu => Setup => ADSB => Options => Select Device => Avidyne'
Once connected, iFly will consume the following IFD data:- ADS-B data (Wx, Nexrad, Traffic, Notams, etc)
- GPS ownship updates (location, altitude, course, and speeds).
- AHRS updates (if supported by your IFD).
- Download Route from IFD to iFly.
- AutoDownload Option, to auto-accept all Route changes then made on the IFD.
- Upload Route from iFly to IFD.
- Reset Session - in case Up/Downloading stops working (rarely needed)
- Custom/User Waypoints contained in the active Flight Plan will be sync'ed
- Full support for IFR routes with Procedures and Airways.
